RG-S5300-48GT4XS-E Schalter - 1
RG-S5300-48GT4XS-E Schalter - 2
RG-S5300-48GT4XS-E Schalter - 3
RG-S5300-48GT4XS-E Schalter - 4
RG-S5300-48GT4XS-E Schalter - 5
RG-S5300-48GT4XS-E Schalter - 6
RG-S5300-48GT4XS-E Schalter - 7
RG-S5300-48GT4XS-E Schalter - 8
RG-S5300-48GT4XS-E Schalter - 9
RG-S5300-48GT4XS-E Schalter - 10
RG-S5300-48GT4XS-E Schalter - 11
RG-S5300-48GT4XS-E Schalter - 12
RG-S5300-48GT4XS-E Schalter - 13
RG-S5300-48GT4XS-E Schalter - 14
RG-S5300-48GT4XS-E Schalter - 15
RG-S5300-48GT4XS-E Schalter - 16
RG-S5300-48GT4XS-E 48-Port GE Electrical Layer 3 Managed Access Switch, 10G Uplink
  • Rich port types, 48 x 1000 Mbps Ethernet ports,4 x 10G optical ports for uplink
Gigabit access switch for large-sized enterprise and campus LANs, with two 10G uplink optical ports for high-speed data transmission 48 x 1000 Mbps Ethernet ports,
providing high-speed network access for short-distance services, and two GE optical ports for flexible networking
RG-S5300-24GT4XS-E
RG-S5300-24GT4XS-P-E
RG-S5300-48GT4XS-E
Built-in power module
System switching capacity *
Number of IGMP groups
Number of MLD groups
Number of VRFs
Weight (full load)
2.7 kg (5.95 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
1.2 GHz dual-core processor
Flash memory: 2 GB
SDRAM: 1 GB
3 MB
< 40 W
< 55 W
AC input: 100 V to 240 V
Frequency: 50/60 Hz
AC input: 90 V to 264 V
5% to 90% RH (non-condensing)
0 m to 5,000 m (16404.20 ft.)
* System switching capacity means the system's switching ccapacity
RG-S5300-E Series
GRE tunnel
Routing policy
IPv4/VRF
Multiple AAA modes
RADIUS
CLI (Telnet/Console)
SNMP v1/v2c/c3
RG-S5300-24GT4XS-P-E:
RG-S5300-24GT4XS-E
RG-S5300-48GT4XS-E
