RG-DEMUX(C)-24LC/LC Schalter - 1
RG-DEMUX(C)-24LC/LC Schalter - 2
RG-DEMUX(C)-24LC/LC Schalter - 3
RG-DEMUX(C)-24LC/LC Schalter - 4
RG-DEMUX(C)-24LC/LC Schalter - 5
RG-DEMUX(C)-24LC/LC Schalter - 6
Installation Modes
Solution Advantages
Topology Comparison
Exclusive bandwidth
Ease of Bandwidth Expansion
RG-DEMUX(C)-24LC/LC
RG-DEMUX-48LC/LC
RG-MUX-48LC/LC
Name
48-port demultiplexer
3 groups
6 groups
3 groups
Installation location
Core side
Core side
Building side
24
Dimension (W × D × H)
297.6 mm * 438.5 mm * 40.2 mm
210.2 mm * 440 mm * 39.8 mm
RG-DEMUX(C)-24LC/LC
Item
RG-DEMUX(C)-24LC/LC
Center wavelength
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
Channel bandwidth
± 6.5 nm
Insertion loss
Return loss
> 45 dB
Polarization dependent loss
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 35 dB
Connector
LC/UPC
10% to 90% RH
5% to 90% RH
Standards
GR-1221-Core and GR-1209-Core
Net weight
3.05 kg (6.72 lbs)
Three groups
24
Dimension (W x D x H)
RG-DEMUX-48LC/LC
Item
RG-DEMUX-48LC/LC
Center wavelength
Channel spacing
20 nm
Channel bandwidth
± 6.5 nm
Insertion loss
Return loss
> 45 dB
< 0.3 dB
> 25 dB
> 35 dB
Connector
LC/UPC
10% to 90% RH
5% to 90% RH
Standards
Net weight
3.49 kg (7.69 lbs)
Six groups
RG-MUX-48LC/LC
Item
RG-MUX-48LC/LC
Center wavelength
Channel spacing
20 nm
Channel bandwidth
± 6.5 nm
Insertion loss
Return loss
> 45 dB
< 0.3 dB
> 25 dB
> 35 dB
Connector
LC/UPC
10% to 90% RH
5% to 90% RH
Standards
Net weight
3.01 kg (6.64 lbs)
Three groups
