Diverse ports, four service slots, up to 128 x 100GE QSFP28 ports or 64 x 100GE QSFP28 and 16 x 400GE QSFP-DD ports
Hardware-level redundancy, ensuring service continuity
Lossless Ethernet, ensuring zero packet loss during RDMA E2E communication
Telemetry-based network monitoring and automated O&M, making management simple and efficient
Highly-efficient heat dissipation and energy saving, with power consumption less than 1950 W and power conversion efficiency up to 94%
RG-S6920-4C |
Ports |
100GE/400GE ports |
Expansion Modules |
Four expansion modules, with each module supporting 32 × 100GE ports |
Expansion Slots |
Four power supply module slots Six fan module slots |
Management Port |
Switching Capacity |
25.6 Tbps |
Packet Forwarding Rate |
8000 Mpps |
802.1Q VLAN |
4094 |
RG-S6920-4C |
Dimensions |
442 mm × 173.5 mm × 735 mm, 4 RU |
About 43.5 kg (including all line cards, power supply modules, and fans) |
RG-S6920-4C |
Maximum Power Consumption |
1950 W |
AC |
Rated voltage range: 100 VAC to 240 VAC, 50 Hz to 60 Hz Maximum voltage range: 90 VAC to 264 VAC, 50 Hz to 60 Hz |
High-voltage DC |
Input voltage range: 192 VDC to 288 VDC |
RG-S6920-4C |
Operating Temperature |
0°C to 40°C |
Operating Humidity |
Software Specifications |
RG-S6920-4C |
L2 Protocols |
L3 Protocols (IPv4) |
IPv6 Basic Protocols |
IPv6 Features |
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, MLDv1/v2, PIM-SMv6, manual tunnel and IPv4 over IPv6 tunnel |
Data Center Features |
PFC, ECN, and other data center features M-LAG RDMA OpenFlow 1.3 |
Visualization |
gRPC sFLOW sampling INT |
QoS |
HA Design |
Security Features |
Management Mode |
SNMP v1/v2/v3, telnet, console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP, Syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm function, temperature alarm function, and configuration rollback |
Other Protocols |
The configuration procedure for the RG-S6920-4C switch is as follows:
● Select the switch.
● Select expansion modulesbased on business requirements.
● Select Optical Transceivers based on port requirements.
Product Model |
RG-S6920-4C |
Four expansion slots, four power supply module slots, and six fan module slots |
RG-PA1200I-F |
M2EFAN I-F |
Fan module, supporting 5+1 redundancy, hot swapping, and front-to-rear ventilation design |
Product Model |
M6900-32CQ |
32 x 100GE ports |
M6900-16CQ4QC |
16 × 100GE optical ports (QSFP28) + 4 × 400GE optical ports (QSFP-DD) |
