RG-SF2920-16GT2MG2XS Schalter - 1
RG-SF2920-16GT2MG2XS Schalter - 2
RG-SF2920-16GT2MG2XS Schalter - 3
RG-SF2920-16GT2MG2XS Schalter - 4
RG-SF2920-16GT2MG2XS Schalter - 5
RG-SF2920-16GT2MG2XS Schalter - 6
Fixed single AC power supply
1000
Ingress: 1500
16 MB flash memory
16 MB flash memory
16 MB flash memory
8 MB
8 MB
8 MB
< 60 W (with PoE full load)
< 15 W
< 150 W (with PoE full load)
40°C (104°F): > 300K
Rack: (32°F to 113°F)
2 x 1/10G SFP+ ports
2 x 1G SFP optical ports
256 MB flash memory
256 MB flash memory
256 MB flash memory
12 MB
12 MB
12 MB
2 x 1G SFP ports
2 x 1G/10G SFP+ ports
2 x 1G/10G SFP+ ports,
26.8 Mpps
56.5Mpps
76 Gbps
2.81 kg (6.20 lbs)
256 MB flash memory
256 MB flash memory
256 MB flash memory
12 MB
12 MB
12 MB
