RG-S7808C Schalter - 1
RG-S7808C Schalter - 2
RG-S7808C Schalter - 3
RG-S7808C Schalter - 4
RG-S7808C Schalter - 5
RG-S7808C Schalter - 6
RG-S7808C Schalter - 7
RG-S7808C Schalter - 8
RG-S7808C Schalter - 9
RG-S7808C Schalter - 10
RG-S7808C 10 RU Modular Campus Core Switch
Modular Core Switch RG-7808C
Compact chassis design with a height of 10 RU improves cabinet space utilization. A single card supports up to 52 non-combo ports, meeting the networking requirements of small and medium-sized core networks or medium-sized network aggregation scenarios.
N+M Power Supply Redundancy
1+1 Fan Module Redundancy
Hareware Specifications
S7805C
S7808C
S7810C
Supervisor module slot
Line card slot
Switch fabric module slot
Built-in
4,500 Mpps
9,000 Mpps
12,000 Mpps
System switching capacity *
6 Tbps
12 Tbps
16 Tbps
EB card: 64,000
FA card: 80,000
FB card: 96,000
EB card: 4,000
DA card: 10,000
FA card: 4,000
● FB card: 40,000
EB card: 8,000
DA card: 16,000
FA card: 8,000
FB card: 16,000
EB card: 4,000
DA card: 8,000
FA card: 4,000
FB card: 8,000
● Ingress
EB card: 3,500
DA card: 8,000
FA card: 5,000
FB card: 4,500
● Egress
EB card: 1,000
DA card: 1,000
FA card: 1,000
● FB card: 2,000
32.35 kg (71.32 lbs)
35.6 kg (78.48 lbs)
43.6 kg (96.12 lbs)
● Supervisor module
● Service module
● Supervisor module
● Service module
● Supervisor module
● Service module
● Switch fabric module
M7805C-CM II: 1 GB
EA card: 512 MB
EB card: 512 MB
DA/F card: 8 GB
M7805C-CM II: DDRIII 4 GB
EA card: DDR3 1 GB
EB card: DDRIII 1 GB
DA card: DDR4 1 GB
F card: DDR4 2 GB
Supervisor module:
M7808C-CM II: 8 GB
Service module:
EA card: 512 MB
EB card: 512 MB
DA/F card: 8 GB
Supervisor module:
M7808C-CM II: DDR4 4 GB
Service module:
EB card: DDR3 1 GB
DA card: DDR4 1 GB
F card: DDR4 2 GB
Supervisor module:
M7810C-CM/M7810C-CM-F: 8 GB
Service module:
EB card: 512 MB
DA/F card: 8 GB
Switch fabric module:
M7810C-FE-D I: 8 GB
M7810C-FE-F I: 8 GB
Supervisor module:
Service module:
EB card: DDR3 1 GB
DA card: DDR4 1 GB
F card: DDR4 2 GB
M7810C-FE-D I card: DDR4 1 GB
M7810C-FE-F I: DDR4 2 GB
RG-S7805C: < 80 W
Supervisor module:
M7805C-CM II: < 21 W
Service module:
M7800C-48GT4XS-EB: < 70 W
M7800C-48SFP4XS-EB: < 101 W
M7800C-32XS4QXS-DA: < 210 W
M7800C-48GT-FA: < 75 W
M7800C-48SFP-FA: < 95 W
M7800C-48XS-FB: < 160 W
M7800C-8CQ-FB: < 130 W
RG-S7808C: < 176 W
Supervisor module:
M7808C-CM II: < 50 W
Service module:
RG-S7810C: < 432 W
Supervisor module:
M7810C-CM: < 50 W
M7810C-CM-F: < 110 W
Service module:
M7810C-FE-D I: < 50 W
M7810C-FE-F I: < 105 W
180 V to 264 V; Power: 300 W
180 V to 264 V; Power: 460 W
● RG-PA600I-F: 600 W
● RG-PA1600I-F:
90 V to 180 V: 12,00 W
180 V to 264 V: 1,600 W
● RG-PA600I: 600 W
● RG-PA1600I:
90 V to 180 V: 1,200 W
● Supervisor module
Right-to-left airflow
● Service module
Right-to-rear airflow
● System power module
● Line card
Side-to-rear airflow
● Supervisor module/FE
RG-S7800C Series
IPv4/IPv6 IS-IS
EVPN
Policy-based routing (PBR)
IPv4 and IPv6 ECMP
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
MPLS IPv6
MPLS 6VPE
Port-based rate limiting
802.1p
CAR
VRRP for the super-VLAN
SPAN, RSPAN, and ERSPAN
FTP, TFTP, and Xmodem
Web-based NMS
S7805C
S7808C
S7810C
M7805C-CM II
M7808C-CM II
M7810C-CM
M7810C-CM-F
Notes:
Power Modules and Fan Modules
RG-PA300I-F
RG-PA460I-F
RG-PA600I-F
RG-PA1600I-F
RG-PA600I
RG-PA1600I
Switch Fabric Modules
M7810C-FE-D I
M7810C-FE-F I
M7800C-48XS-FB
M7800C-8CQ-FB
M7800C-48GT-FA
M7800C-48SFP-FA
M7800C-32XS4QXS-DA
M7800C-48GT4XS-EB
M7800C-48SFP4XS-EB
Notes:
