RG-S6110-48MG4VS2QXS-UP Schalter - 1
RG-S6110-48MG4VS2QXS-UP Schalter - 2
RG-S6110-48MG4VS2QXS-UP Schalter - 3
RG-S6110-48MG4VS2QXS-UP Schalter - 4
RG-S6110-48MG4VS2QXS-UP Schalter - 5
RG-S6110-48MG4VS2QXS-UP Schalter - 6
RG-S6110-48MG4VS2QXS-UP Schalter - 7
RG-S6110-48MG4VS2QXS-UP Schalter - 8
RG-S6110-48MG4VS2QXS-UP Schalter - 9
RG-S6110-48MG4VS2QXS-UP Schalter - 10
RG-S6110-48MG4VS2QXS-UP Schalter - 11
RG-S6110-48MG4VS2QXS-UP Schalter - 12
5G/2.5G/1G/100M access, PoE/PoE+/PoE++, 4 x 25G and 2 x 40G uplink optical ports, offering flexible networking options to build high-performance campus networks
  • 48 x 5G/2.5G/1G/100M Base-T Ethernet ports and 4 x 25G and 2 x 40G uplink ports, meeting high bandwidth demands of large campuses
Multi-GE Access
High-Power PoE Power Supply
Sound QoS Policies
Energy Saving
RG-S6110-24MG4VS-UP
 RG-S6120-24XMG4XS4VS-UP-H
RG-S6120-48XMG4VS2QXS-UP-H
4 x 10GE/25GE SFP28 ports
1 x built-in power module
392 Mpps
750 Mpps
678 Mpps
982 Mpps
System switching capacity *
528 Gbps
1008 Gbps
912 Gbps
1320 Gbps
Egress: 1,000
3.65 kg (8.05 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
6.11 kg (13.47 lbs)
1.2 GHz single-core processor
1 GB DDR4
1 GB flash memory
2 GB DDR4
1 GB flash memory
1 GB DDR4
1 GB flash memory
2 GB DDR4
1 GB flash memory
Without PoE: < 120 W
Full PoE load: < 370 W
Without PoE: < 240 W
Full PoE load: < 1,600 W
Full PoE load: < 1,650 W
Frequency: 50/60 Hz
RG-PA600I-P-F:
● AC input: 100 V AC to 240 V AC
● Frequency: 50/60 Hz
90 V AC to 264 V AC
22.18 years
27.02 years
22.18 years
27.02 years
Front/Left-to-rear airflow
5% to 90% RH (non-condensing)
Maximum value < 78 dBA
6 kV
Software Specifications
RG-S6100 Series
Stateless Auto Configuration
GR for RIP, OSPF, and BGP
Ruijie Could-based management
 and Power Modules
RG-S6110-24MG4VS-UP
GE Optical Module
10GE Optical
Modules
62.5 μm/125 μm: 33 m
50 μm/125 μm: 66 m
25GE Optical
Modules
40GE Optical
Modules
