RG-N18000 Series support
Supported VSU and VSD
Comparison of Port Bandwidths
Frame Size (bytes)
Latency Comparison
Frame Size | 64-byte | 128-byte | 512-byte | 1518-byte | 4096-byte | 9216-byte |
Cut-Through Latency (μs) | 0.532 | 0.545 | 0.588 | 0.586 | 0.586 | 0.586 |
Store -and-Forward LIFO Latency (μs) | 0.650 | 0.651 | 0.666 | 0.665 | 0.665 | 0.665 |
Frame Size | Cut-Through Latency (μs) | Store -and-Forward LIFO Latency (μs) |
64-byte | 0.532 | 0.650 |
128-byte | 0.545 | 0.651 |
512-byte | 0.588 | 0.666 |
1518-byte | 0.586 | 0.665 |
4096-byte | 0.586 | 0.665 |
9216-byte | 0.586 | 0.665 |
Uplink Failure | Main and Backup control modules switch over (Main control module failure) | Backup control module failure | Main switch failure | Backup switch failure | |
Average Convergence Time | 30ms | 0 | 0 | 11ms | 11ms |
Average Convergence Time | |
Uplink Failure | 30ms |
Main and Backup control modules switch over (Main control module failure) | 0 |
Backup control module failure | 0 |
Main switch failure | 11ms |
Backup switch failure | 11ms |
Uplink failover: 35 ms
Stability
Tolly Certified Features | ||
4 Mem mber Virtual Switch Unit (VSU) with RG-N18010 | ||
![]() | Virtual Switch Dev vice (VSD) - virtualize one RG-N18010 into12 virtual switch devices | |
![]() | OpenFlow 1.3 Main Feature | |
![]() | Modular System | (ISSU) for Control Modules |
![]() | Stateless Process Restart | |
![]() | Hot Process Patching | |
![]() | N+1 Fabric Module Redundancy | |
![]() | Hot Swappable Fabric Module |
Power Consumption Analysis
Without Any Line Card | Load All Modules - 0% Traffic | Load All Modules - 30% Traffic | Load All Modules - 100% Traffic | Difference between 100% traffic and without any line card | Average Apparent Power per line card with 100% traffic | Average Apparent Power per 40GbE port with 100% traffic |
Apparent Power | 1.456VA | 2.573VA | 2.742VA | 3.108VA | 1.652VA | 206.5VA | 8.6VA |
Apparent Power | |
Without Any Line Card | 1.456VA |
Load All Modules - 0% Traffic | 2.573VA |
Load All Modules - 30% Traffic | 2.742VA |
Load All Modules - 100% Traffic | 3.108VA |
Difference between 100% traffic and without any line car | 1.652VA |
Average Apparent Power per line card with 100% traffic | 206.5VA |
Average Apparent Power per 40GbE port with 100% traffic | 8.6VA |
Frame Size (bytes)
Latency Comparison
Stability
Apparent Power | |
Ruijie RG-N18000 Series can act as the core of unified authentication and gateway of the campus network to offer simplified network experience for users. As the centralized authentication gateway, the core device can achieve unified assignment of security policies. The access layer and aggregation layer are only responsible for Layer 2 forwarding. As the device maintenance is simpler, the performance capacity is no longer a bottleneck. The core layer device provides rich features, high performance and high reliability. The centralized management of network management policies facilitates security monitoring, network expansion and new service development. The Ruijie RG-N18000 Series supports multiple authentication modes such as Portal/ 802.1X. MAC. Different management modes and technologies will be deployed in different scenarios according to different user requirements of the campus network so as to provide targeted and high-availability technologies and solutions.
World’s Leading Cloud Network Core
Advanced CLOS Architecture
Virtual Switch Unit 3.0 (VSU)The series supports the Virtual Switch Unit 3.0 (VSU). The technology can virtualize multiple physical devices into one logical unit, which largely minimizes the number of network nodes and reduce administrator workload. Superior 50~200ms link failover ensures smooth and uninterrupted transmission of key services. The RG-N18000 Series supports cross-device link aggregation for easy double uplink to server/switch. The network can effectively maximize bandwidth investment return.
Virtual Switch Device (VSD)
Core Concepts
●Decoupling of control plane and forwarding plane → hardware / network unified abstraction & virtualization, ease of independent development
●Centralized control & distributed forwarding → convert the distributed protocol problem into algorithm problem
●Open programming interface → softwarization of hardware, programmable devices, scalable network features & higher flexibility
Solution Components
●Hardware Switching Devices:
Ruijie Newton 18000 and S6000 series platforms will fully support OpenFlow modular hardware switching
●SDN Controller RG-IONC
○MPLS L3 VPN service
Model | RG-N18007 | RG-N18010 | RG-N18012 | RG-N18014 |
Module Slots | 7 (2 for control engines) | 10(2 for control engines) | 12(2 for control engines) | 14 (2 for control engines) |
Modular Power Slots | 6 (4 for system power; 2 for PoE power) | 10 (8 for system power; 2 for PoE power) | 6 (all for system power) | 8 (all for system power) |
Fan Slots | 1 | 4 | 2 | 5 |
Control Engine Slots | 2 | 2 | 2 | 2 |
Service Module Slots | 5 | 8 | 10 | 12 |
Fabric Engine Slots | N/A | 4 | 4 | 4 |
Switching Capacity | 50Tbps/208.5Tbps | 80Tbps/333.6Tbps | 100Tbps/417Tbps | 120Tbps/500.4Tbps |
Packet Forwarding Rate | 900Mpps | 11,520Mpps | 3,840Mpps | 17,280Mpps |
Max. Number of 10GE Ports | Up to 240 | Up to 768 | Up to 480 | Up to 1,152 |
Max. Number of 40GE Ports | Up to 60 | Up to 192 | Up to 120 | Up to 288 |
Max. Number of 100GE Ports | N/A | Up to 96 | Up to 120 | Up to 144 |
PoE | Support | Support | N/A | N/A |
Port Buffer | Up to 16MB | Up to 24GB | Up to 24MB | Up to 24GB |
ARP Table | Up to 170K |
MAC Address | Up to 512K | Up to 512K | Up to 225K | Up to 512K |
Routing Entries | Up to 384K |
Routing Table Size | Up to 12K/6K | Up to 384K/128K | Up to 384K/128K | Up to 384K/128K |
Multicast Entries | Up to 16K/8K |
ACL Entries | Up to 8K |
VLAN | 4K |
QinQ | Basic QinQ, Flexible QinQ |
Link Aggregation | AP, LACP |
Port Mirroring | Many-to-one mirroring, One-to-many mirroring, Flow-based mirroring, Over devices mirroring, VLAN-based mirroring, VLAN-filtering mirroring, AP-port mirroring, RSPAN |
Spanning Tree Protocols | STP, RSTP and MSTP |
DHCP | Support DHCP relay, DHCP snooping, DHCP server, DHCP client |
Multiple Spanning Tree (MST) Instances | 64 (not include default 0) |
Maximum Aggregation Port (AP) | Up to 256 |
Virtual Routing and Forwarding (VRF) Instances | Up to 2K |
Data Center Unified Network Features | L2 GRE |
VXLAN | VXLAN Layer 2 Bridge, VXLAN Layer 3 Bridge, EVPN VXLAN |
SDN | OpenFlow |
VSU (Virtual Switch Unit) | Up to 2 stack members |
VSD (Virtual Switch Device) | Up to 12 VSD units |
L2 Features | Jumbo Frame, 802.1Q, STP, RSTP, MSTP, Port-based VLAN, Super VLAN, Private VLAN, Protocol-based VLAN, IP subnet-based VLAN, Guest VLAN, GVRP, QinQ, Flexible QinQ, LLDP, ERPS (G.8032) Tip: Guest VLAN features are only supported by specific software versions |
Layer 2 Protocols | IEEE802.1d (STP), IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping, Jumbo Frame (9Kbytes), IEEE802.1ad (QinQ and flexible QinQ), GVRP |
Layer 3 Features | ARP, IPv4/v6, PBR v4/v6 |
Layer 3 Protocols (IPv4) | Ping, Traceroute, Equal-Cost Multi-Path Routing (ECMP), URPF, GRE Tunnel(4 over 6), GRE Tunnel(6 over 4), IPv4 VRF |
Centralized Authentication (With RG-SAM+ Integration) | 60K IPv4 and IPv6 dual-stack concurrent users; 1,000 devices per second authentication speed; Authentication modes including 802.1x/ Portal/Mac/IPoE; Portal authentication, RADIUS and TACACS+ user authentication; Layer 2 portal, Layer 3 portal authentication; Traffic billing, traffic control, refined management; Gateway authentication |
IPv4 Features | Static routing, RIP, OSPF, IS-IS, BGP4, VRRP, Equal-cost routing, Policy-based routing, GRE tunnel |
IPv6 Features | Static routing OSPFv3, BGP4+, IS-ISv6, MLDv1/v2, VRRPv3, Equal-cost routing, Policy-based routing, Manual tunnel, Auto tunnel, ISATAP tunnel, GRE tunnel |
Basic IPv6 Protocols | DHCP Relay v6, DHCP Server v6, Telnet v6, TFTP Client v6, FTP v6, NTP client v6, NTP server v6 |
IPv6 Routing Protocols | RIP, RIPng, OSPFv2/v3, BGP4, BGP4+, IS-ISv4/v6, Routing Policy |
IPv6 Tunnel Features | 6over4 Manual Tunnel, 6to4 Auto Tunnel, Manual Tunnel, Auto Tunnel, ISATAP Tunnel, IPv4 over IPv6 Tunnel, IPv6 over IPv6 Tunnel, GRE Tunnel(4 over 6), GRE Tunnel(6 over 6) |
Multicast | IGMP v1/v2/v3, IGMP proxy, Multicast routing protocols (PIM-DM, PIM-SM, PIM-SSM), MLD, Multicast static routing |
MPLS | MPLS forwarding, MPLS VPN, VPLS/VPWS , LDP, LSP |
G.8032 | Support |
ACE Capacity | Up to 8K |
ACL | Standard/Extended/Expert ACL; ACL 80; IPv6 ACL |
QoS | 802.1p, Queue scheduling mechanisms (SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, SP+DRR, and 8 hardware queues at egress ports), RED/WRED, Input/output port-based speed limit |
IPv6 ACL | Support |
Reliability | Control engine 1+1 redundancy; power supply 1+1 redundancy; Hot-swappable components; Hot patch and online patch upgrade; GR for OSPF/IS-IS/BGP; BFD for VRRP/OSPF/BGP4/ISIS/ISISv6/static routing |
EEE Format | Support EEE (802.3az) |
Security | NFPP (Network Foundation Protection Policy), CPP (CPU Protection), DAI, ARP Check, Port Security, IP Source Guard, 802.1x, Portal authentication, RADIUS and TACACS+ user login authentication, uRPF, Account privileges and password security policy, Unknown multicasts are not delivered to CPU and support unknown unicasts suppression, Support SSHv2 to provide a secure and encrypted channel for user login |
Manageability | Console/AUX Modem/Telnet/SSH2.0 command line configuration; FTP, TFTP, Xmodem file upload/download management; SNMP V1/V2c/V3; RMON; NTP clock; Fault alarm and self-recovery; System log; sFlow |
Hot Patch | Support |
CWMP | Support |
Smart Temperature Control | Fan speed auto-adjustment; Fan malfunction alerts; Fan status check |
Smart Power Supply | Support power control and management |
Other Protocols | DHCP client, DHCP relay, DHCP server, ARP proxy, Syslog |
Dimensions | 442 x 598 x 352.8 | 442 x 836 x 797.3 | 442 x 725 x 708.4 | 442 x 814 x 886.2 |
Rack Height | 8RU | 18RU | 16U | 20RU |
Weight | 30.2kg | 103.32kg | 105kg(total weight of empty chassis and fans) | 107.55kg |
MTBF | 229K hours | 259K hours | 259K hours | 216K hours |
Power Supply | RG-PA1600I: 90-180V~ 1200W; 180-264V~ 1600W RG-PA600I: 90-180V~ 600W; 180-264V~ 600W RG-PD1600I: -40.5VDC-75VDC ~1600W RG-PD600I: -40.5VDC-75VDC ~600W RG-PA1600I-PL: 90-180V~1000W; 180-264V~1600W RG-PA3000I-PL: 90-180V~ 1200W; 210-264V~ 3000W | RG-PA1600I: 90-180V~ 1200W; 180-264V~ 1600W, 16A RG-PA600I: 90-180V~ 600W; 180-264V~ 600W, 10A RG-PD1600I: -40.5VDC-75VDC ~1400W RG-PD600I: -40.5VDC-75VDC ~600W RG-PA1600I-PL: 90-180V~1000W; 180-264V~1600W (PoE) RG-PA3000I-PL: 90-180 V~1200W; 210-264V~3000W (PoE) | RG-PA1600I: 90-180V~1200W; 180-264V~ 1600W; 16A RG-PA600I: 90-180V~ 600W; 180-264V~ 600W; 10A RG-PD1600I: -40.5VDC-75VDC ~1400W RG-PD600I: -40.5VDC-75VDC ~600W | RG-PA1600I: 90-180V~ 1200W; 180-264V~ 1600W, 16A RG-PA600I: 90-180V~ 600W; 180-264V~ 600W, 10A RG-PD1600I: -40.5VDC-75VDC ~1400W RG-PD600I: -40.5VDC-75VDC ~600W |
Power Consumption | <432W | <730W | <518W | <860W |
PoE Power | <6,000W | <6,000W | N/A | N/A |
Temperature | Operating temperature: 0ºC to 50ºC |
Storage temperature: -40ºC to 70ºC |
Humidity | Operating humidity: 10% to 90% RH (non-condensing) |
Storage humidity: 5% to 95% RH |
Operating Altitude | -500m to 4,000m |
Weight and Typical Power
Component | Weight | Maximum Power |
Main Chassis |
| 30.2kg | 432W |
| 103.32kg | 730W |
| 105kg | 518W |
| 107.55kg | 860W |
Control Engine |
1.68 kg | 40W |
| 2.0kg | 102W |
| 2.0kg | 102W |
| 1.68kg | 40W |
| 2.04kg | 95W |
| 1.68kg | 40W |
| 2.0kg | 95W |
| 3.22kg | 40W |
| 3.58kg | 100W |
Fabric Engine |
| 2.72kg | 90W |
| 2.8kg | 107W |
| 3.36kg | 313W |
| 2.2kg | 107W |
| 3.76kg | 158W |
| 4.56kg | 425W |
Power Supply |
| 2.04kg | N/A |
| 1.64kg |
| 1.6kg |
1.6kg |
| 1.6kg |
| 1.6kg |
| 1.3kg |
Line Card & Service Module |
| 3.76kg | 135W |
| 3.86kg | 175W |
| 5.06kg | 267W |
| 3.7kg | 95W |
| 3.8kg | 175W |
| 4.04kg | 95W |
| 3.76kg | 100W |
| 3.42kg | 85W |
| 3.52kg | 120W |
| 4.20kg | 156W |
| 4.50kg | 250W |
| 5.20kg | 296W |
| 4.25kg | 232W |
| 4.0kg | 208W |
| 3.92kg | 200W |
| 4.95kg | 374W |
| 5.4kg | 366W |
Multiservice Module |
| 4.58kg | 190W |
| 4.58kg | 190W |
| 4.58kg | 190W |
The Ruijie Newton 18000 platform is applicable to a wide range of deployment scenarios. The series can act as the core for large campus network, data center network, integrated network of data center and campus network, and large MAN. Respective illustrations are shown below.
Large Campus Network Core
Model | Description |
RG-N18000 Series Main Chassis & Control Engine |
RG-N18014 | 14-slot Chassis with fan (without power supply) |
RG-N18012 | 12-slot Chassis with fan (without power supply) |
RG-N18010 | 10-slot Chassis with fan (without power supply) |
RG-N18007 | 7-slot Chassis with fan (without power supply) |
M18014-CM II | N18014 2nd Generation Control Engine |
M18014-CM | N18014 Control Engine |
M18012-CM II | N18012 2nd Generation Control Engine |
M18012-CM | N18012 Control Engine |
M18010-CM II | N18010 2nd Generation Control Engine |
M18010-CM | N18010 Control Engine |
M18007-CM | N18007 1st Generation Control Engine |
M18007-CM II | N18007 2nd Generation Control Engine |
M18007-CM II Lite | N18007 2nd Generation Lite Control Engine |
2. Power Supply
RG-PA600I | N18000 Power Module (support redundancy, AC, 600W, 10A) |
RG-PD600I | N18000 Power Module (support redundancy, DC, 600W) |
RG-PA1600I | N18000 Power Module (support redundancy, AC, 1600W, 16A) |
RG-PD1600I | N18000 Power Module (support redundancy, DC, 1400W) |
RG-PA1600I-PL | N18000 PoE Power Module (support redundancy, AC, 1600W, 16A) |
RG-PA3000I-PL | N18000 PoE Power Module (support redundancy, AC, 3000W, 16A) |
3. Fabric Engine
M18014-FE-D III | N18014 D Series 3rd Generation Fabric Engine (For ED and DB series Line Card and Service Module) |
M18014-FE-D I | N18014 D Series 1st Generation Fabric Engine (For ED and DB series Line Card and Service Module) |
M18012-FE-D I | N18012 D Series 1st Generation Fabric Engine |
M18010-FE-D III | N18010 D Series 3rd Generation Fabric Engine (For ED and DB series Line Card and Service Module) |
M18010-FE-D I | N18010 D Series 1st Generation Fabric Engine (For ED and DB series Line Card and Service Module) |
M18010-FE-C I | N18010 C Series 1st Generation Fabric Engine (For CB series Line Card and Service Module) |
4. Line Card & Service Module
M18000-44SFP4XS-ED | 44 Gigabit Ethernet fiber ports (SFP, LC), 4-port 10GE Ethernet optical interface board (SFP+, LC) |
M18000-44SFP4XS-EF | 44 Gigabit Ethernet fiber ports (SFP, LC), 4-port 10GE Ethernet optical interface board (SFP+, LC) |
M18000-48GT-ED | 48-port Gigabit Ethernet electrical interface board (RJ45) |
M18000-48GT-EF | 48-port Gigabit Ethernet electrical interface board (RJ45) |
M18000-48GT-P-ED | 48-port Gigabit PoE Ethernet electrical interface board (RJ45) |
M18000-24GT20SFP4XS-ED | 24-port Gigabit Ethernet electrical interface board (RJ45), 20 Gigabit Ethernet fiber ports (SFP, LC), 4 10GE Ethernet fiber ports (SFP+, LC) |
M18000-08XS-ED | 8 10GE fiber ports (SFP+, LC) |
M18000-08XS-EF | 8 10GE fiber ports (SFP+, LC) |
M18000-16XT-CB | 16 10GE copper ports (RJ45) |
M18000-48XS-DC | 48 10GE fiber ports (SFP+, LC) |
M18000-24XS4QXS-DC | 24 10GE fiber ports (SFP+, LC) + 4-port 40GE optical interface module (QSFP+, MPO) |
M18000-12QXS-DC | 12 40GE fiber ports (QSFP+, MPO) |
M18000-24QXS-DB | 24 40GE fiber ports (QSFP+, MPO) |
M18000-12CQ-EH | 12 100GE fiber ports(QSFP28) |
Multi-service Line Card |
RG-WALL 1600-B-ED | Firewall card, 2 10GE fiber ports (SFP+, LC) |
M18000-MSC-ED | Service module with Gateway authentication and accounting function, integrated with high-level core switches RG-N18000 series, to support authentication, throughput based accounting, URL audit and flow control function. |
M18000-WS-ED | WS Series Wireless Controller Module for RG-N18000 Switch Series, 2 1G/10GBASE-X SFP+ ports, 128 APs License by default, maximum 2560 APs or 4000 Wall APs License |
5. Transceiver and Cable
Mini-GBIC-SX-MM850 | 1000BASE-SX mini GBIC Transceiver (850nm) |
Mini-GBIC-LX-SM1310 | 1000BASE-LX mini GBIC Transceiver (1310nm) |
Mini-GBIC-GT | 1000BASE-TX, SFP Transceiver (100m) |
Mini-GBIC-LH40-SM1310 | 1000BASE-LH mini GBIC Transceiver, SM (1310nm, 40km) |
Mini-GBIC-ZX50-SM1550 | 1000BASE-ZX mini GBIC Transceiver (1550nm, 50km) |
Mini-GBIC-ZX80-SM1550 | 1000BASE-ZX mini GBIC Transceiver (1550nm, 80km) |
Mini-GBIC-ZX100-SM1550 | 1000BASE-ZX mini GBIC Transceiver (1550nm, 100km) |
XG-SFP-AOC1M | 10GBASE SFP+ Optical Stack Cable (included both side transceivers) , 1 Meter |
XG-SFP-AOC3M | 10GBASE SFP+ Optical Stack Cable (included both side transceivers), 3 Meter |
XG-SFP-AOC5M | 10GBASE SFP+ Optical Stack Cable (included both side transceivers), 5 Meter |
XG-SFP-AOC10M | 10GBASE SFP+ Optical Stack Cable (included both side transceivers), 10 Meter |
XG-SFP-SR-MM850 | 10GBASE-SR, SFP+ Transceiver, MM (850nm, 300m, LC) |
XG-SFP-LR-SM1310 | 10GBASE-LR, SFP+ Transceiver, SM (1310nm, 10km, LC) |
XG-SFP-ER-SM1550 | 10GBASE-ER, SFP+ Transceiver, SM (1550nm, 40km, LC) |
XG-SFP-ZR-SM1550 | 10GBASE-LC, SFP+ Transceiver, SM (1550nm, 80km, LC) |
40G-AOC-5M | 40G Cable for QSFP+, 5M |
40G-QSFP-SR-MM850 | 40GBASE-SR, QSFP+ Transceiver, MM (850nm, 100m with OM3 fiber, 150m with OM4 fiber, MPO) |
40G-QSFP-LSR-MM850 | 40GBASE-SR, QSFP+ Transceiver, MM (850nm, 300m with OM4 fiber, 400m with OM4 fiber, MPO) |
40G-QSFP-LR4-SM1310 | 40G LR Single-mode Fiber Module, QSFP+ Transceiver, LC, 10km (1310nm) |
40G-QSFP-LR4-PSM-SM1310 | 40G LR Single-mode 1-to-4 Fiber Module, QSFP+ Transceiver, LC, 10km (1310nm) |
QSFP-MPO8-4LC-SM-1M | 40G Single-mode 1-to-4 Fiber Jumper, MPO/APC-4*LC/PC, 8 cores, 1m, for 40G-QSFP-LR4-PSM-SM1310 |
QSFP-MPO8-4LC-MM-1M | 40G Single-mode 1-to-4 Fiber Jumper, MPO/APC-4*LC/PC, 8 cores, 1m, for 40G-QSFP-SR-MM850 and 40G-QSFP-LSR-MM850 |
100G-QSFP-LR4-SM1310 | 100G LR Fiber Module, QSFP28 Transceiver, LC, 10km (1310nm) |
100BASE-LX, SFP Transceiver, MM (1310nm, 2km, LC). |
100BASE-LH, SFP Transceiver, SM (1310nm, 15km, LC). |
1000BASE-LX, SFP Transceiver, BIDI-TX1310/RX1550, 20km, LC |
1000BASE-LX, SFP Transceiver, BIDI-TX1550/RX1310, 20km, LC |
1000BASE-LH, SFP Transceiver, BIDI-TX1310/RX1550, 40km, LC |
1000BASE-LH, SFP Transceiver, BIDI-TX1550/RX1310, 40km, LC |
Ruijie Console Cable RJ45-to-DB9 (2m) |
