RG-MF2920U-4GT1MS, 4-Port Gigabit Indoor Wall Plate Switch, with One 2.5GE Uplink Optical Port (Downward Compatibility)
Suitable for hospital scenarios, including doctor's offices, outpatient halls, wards, and imaging rooms
  • Indoor switch, 4 x GE ports with auto-negotiation, 1 x GE/2.5GE optical port, 1:1 exclusive bandwidth
  • 86-type faceplate design, installation without damaging the wall
  • Fanless design, neat and quiet
  • Equipped with the INC controller to achieve simplified and efficient O&M
RG-MF2920U-4GT1MS
Indoor Switch for All-Optical Ethernet
An all-optical network combines Fiber-to-the-Room (FTTR) and Ethernet technologies, implementing 2.5G all-optical access and exclusive bandwidth with one
fiber-optic cable in one room.
86-Type Faceplate Design, Installation Without Damaging the Wall, Fanless, Neat and Quiet
A compact design and an independent mounting plate allow for installation on an 86 mm junction box without damaging the wall. The incorporated splicing tray beneath the switch facilitates effortless and tidy fiber optic cable organization. Next-generation hardware architecture and a fanless design are adopted to ensure silent operation with a noise level below 35 dB, making the device imperceptible to users.
Find out details >>
RG-MF2920U-4GT1MS
4 x 10/100/1000M auto-negotiation electrical ports, 1 x GE/2.5GE SFP port, powered by the adapter
432 Gbps/4.32 Tbps
78 Mpps/126 Mpps
MAC address entries
16K
RG-MF2920U-4GT1MS
Dimension (W x D x H)
160 mm x 86 mm x 21.6 mm (6.30 in. x 3.39 in. x 0.85 in.) (excluding the mounting plate)
160 mm x 86 mm x 28.8 mm (6.30 in. x 3.39 in. x 1.13 in.) (including the mounting plate)
RG-MF2920U-4GT1MS
Frequency: 50 Hz to 60 Hz
RG-MF2920U-4GT1MS
5% to 95% RH
RG-MF2920U-4GT1MS
RSTP
4K IEEE 802.1Q VLANs
DHCP Snooping
Security features
Password protection
EEE
APD port dormancy
Management features
CLI-based configuration and management not required, visualized web-based management
IoT MQTT
Syslog/Debug, NTP/SNTP
RG-MF2920U-4GT1MS
